View OSPF Errors on a Port
Check OSPF errors for administrative and troubleshooting purposes.
  1. Enter Privileged EXEC mode:
    enable
  2. Display extended information about OSPF errors for the specified port or for all ports:
    show ip ospf port-error [port {sub-port]][,...][slot/all][all]}] [vrf WORD<1-16>] [vrfids WORD<0-512>]
Variable definitions
The following table defines parameters for the show ip ospf port-error command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
vrf WORD<1-16>
Specifies the VRF by name.
vrfids WORD<0-512>
Specifies a range of VRFs by ID number.
